Temperature and power consumption:
Temperature :
To record temperatures, we opted for the Superposition stress test in Extreme mode. We opted for three 5-minute runs with 10-minute intervals between each test. We took advantage of this benchmark to record the graphics card’s power consumption for the table above.
To find out the Idle temperature, after completing the three stress test loops, we let the card rest for 20 minutes before taking the temperature reading. Bear in mind that most boards benefit from “0 dBa” technology, so the fans cut out below a certain temperature, often between 50 and 55°C. It therefore takes longer to dissipate heat after a period of stress testing or gaming. A card that does not benefit from this technology will be noisier than others at rest. A quick reminder: our temperature readings are taken in Open-Air. In a closed case, the cards will inevitably be warmer.
This is the second time we’ve tested this cooling system on a high-end model. The system is efficient but not the best in its category, but in compensation, it’s really very quiet. It might be worth modifying the ventilation curve to improve performance.
Power consumption (full configuration) :
We use a wattmeter to measure power consumption at the output of our power supply. Our modular power supply is a CORSAIR AX1600i. The result is the average total power consumption of our configuration. Only the graphics card changes between each reading. This makes it easy to calculate the difference between each graphics card.
But the good news is that we should (finally) be properly equipped to isolate power consumption solely from the graphics card, as we have pre-ordered the BENCHLAB from Elmorlabs.
Power consumption is unsurprisingly a little higher than that of the RTX 4080, rising from 392 to 413 watts for our complete configuration.
