Viewport Mini: a µATX aquarium case from Aerocool!
Aerocool announces a new housing with its Viewport Mini. Clearly, the brand is giving in to the current fashion for Aquarium-type housings with glass fronts and no visible pillars. What’s in it for you? A clear view of the configuration mounted inside!
Viewport Mini: a small aquarium-style case!
Aerocool Viewport MiniThe dimensions of this compact case are 212 (W) x 377.5 (D) x 437 (H) mm.
Internally, it can accommodate micro-ATX and mini-ITX motherboards. With a micro-ATX card, however, you’ll be obstructing cable openings. You’ll have to use other openings.
As far as the graphics card is concerned, it’s got what it takes, with a length of 355 mm, while the CPU cooler benefits from a 165 mm height. Finally, the power supply is 205 mm deep.
As for cooling, by default it comes with three 120 mm fans pre-installed. Other slots are available: two 120/140 mm at the top and two 120 mm on the power supply cover. As for watercooling, compatibility with 240/280 mm radiators is ensured at the top.
At present, the price is not known, but don’t expect an expensive reference.
Here’s the Aerocool product sheet!
