The test configuration:
As we said in the introduction, we’re busy (again) updating all our graphics using the latest drivers from NVIDIA, AMD and, of course, INTEL. We’ve also taken the opportunity to slightly modify our test configuration and add new games to our protocol. So here we go again, with a new series of tests and graphics on this slightly modified configuration:
- Motherboard: ROG Maximus Z690 APEX
- Processor: Intel Alder Lake i9-12900K
- Memory : 32 GB Corsair Vengeance 7200 CL38 DDR5
- Graphics card: KFA2 RTX 4080 SUPER SG 1-Click OC
- Cooling system : ROG Ryujin II 360
- SSD: Western Digital Black SN750 2 TB radiator EKWB
- Power supply: Corsair AX1600i adapter 12VHPWR 600W
- Operating system: Windows 11 64-bit (23H2)
For this test, we used a high-end configuration featuring an i9-12900K processor and DDR5. The use of a 144 Hz 4K display is also a sine qua non. For our tests, we’re using the ROG PG27UQ.
Our test protocol :
All cards are tested at stock frequencies and without any optimization. For the various benchmarks, whether synthetics or games, we’ll opt for 1080p, 1440p and 2160p resolutions, depending on the card’s performance. Here, with this model, we’ll only be using 2160p definition for rasterization and ray tracing, as this seems the most appropriate.
Some cards can straddle the line between two definitions. That’s why some models, like the latest RTX 4070 Ti SUPER, straddle two definitions.
As you can see, we’re now running Windows 11, and we’ve activated the “ReSize BAR” in the BIOS, which can be seen in GPU-Z. As a reminder, we’re still testing the previous generation, and other cards will be added to the various definitions. Now that you know everything about our test configuration, it’s time to get started!
