Protocol
We’ve updated our test protocol in order to test the qualities of our cases. We’ll be assessing the performance of the different models according to three criteria:
- Insulation
- Original ventilation noise
- Air flow
As far as adding ventilation is concerned, we’ve chosen to integrate two Thermaltake Riing 14 red fans. The first will be mounted on the power supply cover, as an intake fan. On the other side, the second fan will be mounted at the rear, also in suction to respect the airflow direction of the original ventilation.
Configuration :
- Processor: AMD Ryzen 7 1700X
- Motherboard: Asus Crosshair VI Hero
- Graphics card: reference ASUS HD 7970
- Cooler: be quiet! Dark Rock 4
- SSD: Corsair Force GS180 Go
- Power supply: NZXT C100 Gold
