Overclocking.com video
Specifications and PCB:
Technical specifications:
In terms of frequency, here’s that of our PowerColor Red Devil RX 7800 XT. The base frequency is announced at 2254 MHz, while the Boost peaks at 2565 MHz. This Red Devil therefore features factory overclocking, since the Boost frequency of the reference card is 2430 MHz. This should outperform the AMD RX 7800 XT. The 16 GB of G-DDR6 memory run at 2438 MHz (624 GB/s) on a 256-bit bus.
A quick run through GPU-Z to check that the information read is correct. Don’t forget that the latter will be higher in benchmarks, depending on the quality of your chip and cooling system.
