Print quality
Print quality
The included USB key also contains a number of G-codes, i.e. pre-sliced templates. A simple solution for testing the printer after installation. There’s the Buddha with a printing time of 40 minutes.
Now to the most important thing of all: print quality. The Buddha in PLA is in orange, PLA Pro in black:
We start small by printing cable combs.
Note the perfect prints, even without adhesive backing with the Elegoo PLA Pro.
Noctua offers the files for its NA-IS1 on Printables. Naturally, we wanted to print some to test later.
Now if the print doesn’t want to set on the PEI plate, we use some of the PVP glue supplied with the printer.
And finally, an interlocking test print. Here, a cable roller to tidy up your tangled cables.
Overall, print quality is good out of the box, but it would certainly be interesting to adjust its profiles for other types of filament.
We’ve just received a large number of filaments and we’ll be offering you profiles for other materials very soon (ASA, PETG, etc.). We’ll need some time to fine-tune the profiles.
![[Tweak League] Tutorial: Overclock your RTX 4060 and get 10% FPS](https://en.overclocking.com/wp-content/medias/sites/4/2024/07/overclocking-gpu-rtx-4060-occ-scaled-218x150.jpg)
