Lenovo has an RTX 4060 ITX in its catalog!
The Lenovo brand now has a small, ultra-compact RTX 4060 ITX in its catalog. In effect, the brand is offering us an ITX model. The only hitch is that this is not a card that will be available for purchase. As usual, the Chinese brand is offering hardware that will be integrated directly into pre-assembled machines.
RTX 4060 ITX: a card available in the brand’s machines!
Lenovo RTX 4060 ITXAs you can see, the card in question is ultra-compact. Its heatsink does not extend beyond the length of the PCIe connector. The latter occupies a strict double-slot format, while cooling is provided by a single fan.
At the same time, the eight-pin power connector migrates to the rear of the board. This positioning is unusual, since it’s mostly found on NVIDIA professional boards. It’s a pity, since it simplifies wiring and hides the connectors as much as possible.
As we said, this is not a board that will be commercially available. For that, you’ll need to purchase a machine pre-assembled by the brand, in this case, an IdeaCenter GeekPro 2023. Configurations include a 13th-generation Core i3 or Core i7, backed by DDR4 RAM and a 1TB SSD for storage.
