Uni FAN SL-Infinity: even more RGB from Lian Li!
Lian Li already has a few fans in its catalog, but is expanding its lineup. Today we learn the launch of Uni FAN SL-Infinity. New fans that integrate an RGB lighting with an infinite depth effect. An effect similar to that of NZXT pumps for example.
Uni FAN SL-Infinity: RGB with infinite depth effect!
Lian Li UNI Fan SL InfinityClearly, the brand puts the package on the lighting part of its fans. First, we will note the presence of 40 diodes per mill. Then, we will note the infinite depth effects on the central hub as well as on the lateral parts of the frame with two illuminated zones.
Of course, we still find the system of connection through the frame. This reduces the number of cables in the installation and improves the wiring. Indeed, we will find only one connector per fan cluster.
Regarding their characteristics, we have mills that can operate from 0 RPM to 2100 RPM. At full speed, the air flow will reach 61.3 CFM and the static pressure 2.66 mmH2O.
We finish by mentioning the controller that will be supplied in the packs of three fans. This last one, via the L-Connect 3 software, will allow the management of the lighting, but also of the speed with a 0 RPM mode.
For the price, inevitably, the bill will climb quite quickly. It will be necessary to count 29,90 € with the unit against 99,90 € in pack of three, with the controller thus. Finally, the L-Connect 3 box is available separately for 24,90 € !
Here is the technical data sheet of Lian Li!
