Skull and Bones: an RTX 2070 in 1080p for 60 FPS!
Ubisoft has announced the system requirements for its next title: Skull and Bones! So what are the system requirements to run the title? Is your PC ready to go? Let’s find out!
Skull and Bones: an RTX 2070 in 1080p 60 FPS in high!
Skull and BonesFor the time being, the title is quite demanding from a hardware point of view since in high 1080p and to reach 60 FPS, you will need :
  • CPU: Intel Core i7 8700K – AMD Ryzen 5 3600
  • GPU: NVIDIA GeForce RTX 2070 (8 GB) – AMD RADEON RX 5700 XT (8 GB)
  • RAM: 16 GB of dual channel memory
Thereafter, the higher the resolution, the more demanding the configuration becomes. In 1440p we have :
  • CPU: Intel Core i7 9700K – AMD Ryzen 5 5600X
  • GPU: NVIDIA GeForce RTX 3070 (8 GB) – AMD RADEON RX 6800 (16 GB)
Finally, in UHD, the configuration passes on :
  • CPU: Intel Core i5 11600K – AMD Ryzen 5 5600X
  • GPU: NVIDIA GeForce RTX 3080 (10 GB) – AMD RADEON RX 6800 XT (16 GB)
  • RAM: 16GB of dual channel memory
Skull and Bones If you can’t afford such an impressive configuration, a GTX 1060/RX570 may suffice. For the CPU part a Core i7 4790 or a Ryzen 5 1600 will suffice, all coupled with 8 GB of memory. With this hardware, you can aim for 30 FPS with low details.
However, you have to keep in mind that the game incorporates Ray Tracing hence the need to have an RTX fairly quickly. Anyway, an SSD with 65GB of storage is recommended to avoid endless load times!
