On the Sharkoon side, we will remember the arrival of new fans with the SilentStorm PWM. Fans with aRGB lighting and available in 120 mm and 140 mm, enough to go everywhere!
SilentStorm PWM: RGB fans in 120 mm and 140 mm!
With its new fans, Sharkoon offers us 120 mm and 140 mm mills. These ones have a classic aRGB lighting since it comes from diodes positioned at the motor. Nothing very original to that. Otherwise, these mills have impressive rubber silentblocks to limit the parasitic vibrations.
As far as their characteristics are concerned, the 120 mm mill will operate from 400 RPM to 1400 RPM. At full speed, it will generate an air flow of 93.6 m3/h while exerting a static pressure of 1.91 mmH2O. The 140 mm version offers the same speed range, however, the air flow will be more important: 121.9 m3/h while the pressure will be slightly lower: 1.47 mmH2O.
We end quickly with the pricing which is rather soft. Indeed, the model in 120 mm is displayed at 10.99 € against 12.99 € for the version in 140 mm.
Go here and here for Sharkoon’s technical specifications !
