Review – Roccat Vulcan II Mini Air
After our tests of the Vulcan II, we’re back with wireless gaming keyboards, this time with Roccat’s new reference, the Vulcan II Mini Air. It’s a keyboard equipped with Titan II switches, in 65t format and capable of carrying up to 4 different profiles! It’s also the brand’s first wireless keyboard.
On top of that, let’s not forget Roccat’s RGB lighting. So, what’s this Vulcan II Mini Air worth? Answer in our test!
Technical specifications :
Roccat unveils a brand-new keyboard reference 65
with the Vulcan II Mini Air. The big news with this one is that it’s wireless. In fact, it’s the brand’s very first wireless keyboard. The brand claims a battery life of up to 240 hours.
The Vulcan II Mini Air is relatively unobtrusive on a desk, measuring just 325 x 124 x 33 mm and weighing just 576 g (without dongle or cable). Here, Roccat’s new keyboard features in-house switches (Titan II) and customizable RGB key by key. In addition, the keys can support up to 150 million activations. Recharging is via a detachable 1.8 m sheathed cable.
The Vulcan II Mini Air also features a 4 MB internal memory, enabling up to 4 profiles to be stored. In addition, it features easy-shift technology for doubling the number of keys on the keyboard, as well as the classic full-key NKRO with integral anti-ghosting . Not to mention 29 integrated shortcuts. And of course, the keyboard features a 1 GHz polling rate.
This model is already available to order for €179.99.
To use Roccat’s Vulcan II Mini Air, you’ll need at least a Windows 7 operating system. You’ll also need a USB 2.0 port and an Internet connection to download the keyboard management software.
[nextpage title=”Unpacking”]
The box:
This little Vulcan II Mini Air arrives in a small, colorful black box. On the front, we’re treated to a pretty representation of our keyboard du jour. It’s illuminated by RGB LEDs. At the same time, we learn that this reference is wireless and 65% form factor. The brand also highlights its red linear switches . Let’s move on to the rear, where we once again have a representation of the keyboard and some additional information on Roccat’s switches. In addition, Roccat indicates that two wireless modes are available with the Vulcan II Mini Air. It is possible to use the 2.4 GHz dongle and/or the Bluetooth connection. What’s more, the lighting automatically adjusts to optimize the keyboard’s battery life.
On opening the box, the keyboard is well protected by cardboard protectors and plastic bags. In any case, this has served its purpose well, as the keyboard arrived in excellent condition.
The bundle:
Don’t expect any accessories with Roccat. All we’ll find here is a charging cable and a quick-start guide. We’re a long way from the days when we could find stickers and storage cases for our peripherals!
The Roccat Vulcan II Mini Air:
The Vulcan II Mini Air is clearly pretty out of the box. It’s simple and elegant. Here, we received a black model, unlike the Vulcan II, which was pristine white. Here too, this Vulcan II Mini Air features an aluminum faceplate that gives it a certain entry-level quality.
What’s more, Roccat’s new keyboard has slim, non-raised keys. This allows the transparent underside of the key to be seen. So, when illuminated, the RGB is much more visible and luminous.
For recharging, this model is equipped with a long, detachable 1.8 m sheathed cable. Unlike Roccat’s Vulcan II Max, you don’t need two USB ports to make full use of it. Phew!
How does it look from the back?
On the back, the rear is somewhat worked, with a few lines. It’s a welcome change from smooth plastic. Otherwise, there are a few rubber pads to help hold this reference in place. We’re also treated to two elevating feet, not forgetting the label in the center with serial numbers and recycling information.
[nextpage title=”Test”]
Let’s move on to the test of Roccat’s Vulcan II Mini Air. We put it to the test in just about every scenario: video games, office automation, etc….
Handling:
If you’re not used to this type of keyboard format, getting to grips with it can be a little complicated at first. In fact, here we lose all the function keys and numeric keypad. Instead, you’ll need to use all the shortcuts found on the Vulcan II Mini Air with a shift . .. or FN … combination. Small size also means double the functions on the keys, especially for multimedia content management. There’s no surprise here: you’ll have to use a dedicated FN key combo. Sound management is handled by the ” , ” , ” ; ” and ” : ” keys, while track management is handled by the ” w ” , ” x ” and ” c ” keys. Finally, lighting intensity is controlled via the keys on the far right of the keyboard.
Nevertheless, we’ve kept the directional arrows, which are not present on 60% format keyboards, such as the K65 RGB Mini.
The main purpose of this type of keyboard is to save space on your desk. Indeed, if you switch from a full-size keyboard (Vulcan II, for example), you’ll clearly see the difference. This Vulcan II Mini Air measures just 325 x 124 x 33 mm, as opposed to the 463 x 236 x 33 mm of the Vulcan II. That’s an enormous space saving in this case. We save an enormous amount of space on our desktops, especially for the mouse. Practical, especially if you want to play at low DPI.
On the other hand, the drawback of having such a compact and small model is its contained weight of just 576 g. On the desk, it can be moved without any blockage, and the rubber bands are clearly not going to change anything.
In use, I found that Roccat’s keyboard wasn’t elevated enough! In fact, I found it a little too low to write on in good conditions, despite the raised legs at the highest level.
Vulcan II Mini Air design:
The design of this Vulcan II Mini Air is in the same vein as that of the Vulcans. In fact, it looks exactly like the Vulcan II we recently tested. Likewise, it has changed very little since the Vulcan II Mini test.
As usual, the keys are divided into two sections. The first is flat and thin (low profile), black in color, with RGB lighting at letter level. The second part of the key is transparent and lets the RGB light through. The result is an ultra-bright, aesthetically pleasing effect.
Nevertheless, unlike Corsair and its K65 Pro Mini, the keys are simply ABS with laser engraving for lettering. What’s more, the brand announces that it will be possible to change keysets easily, since the standard cross-shaped key support is included. However, in ISO version, this promises to be rather complicated given that there are very few sets on the market.
Switches:
The Vulcan II Mini Air comes with two types of switch. These are, of course, Roccat’s Titans II. First, there are the red linear switches . These are designed to be fast, precise and silent. To activate them, you’ll need 1.4 mm for a force of 45 G. Their total travel is 3.6 mm.
In contrast, the brown tactile switches are ideal for those who appreciate tactile switch feedback. The tactile Titans II are less silent than the red ones. To activate them, you’ll need 1.8 mm for a force of 45 G. Their total travel, like the reds, is 3.6 mm.
Our model of the day is equipped with red, linear switches . These switches are more sensitive than Cherry MX Red switches, with an accent point of 2 mm. Here, we’re dealing with a soft, light touch. It doesn’t take much force to activate the key. Despite the fact that these Titan IIs are optical switches, we feel a very slight friction as they descend. We’re on to something smoother than an MX Red (which has more or less been the “classic” switch for a long time) but rougher than Steelseries’ Omnipoint switches .
Of course, sensitive switches are great for gaming, but when it comes to writing, things get a little more complicated. As soon as you slip on another key, you’re bound to make a mistake. All this takes a little getting used to, which fortunately happens very quickly.
Noise:
Unlike MSI’s Vigor GK71 Sonic, the Vulcan II Mini Air is much quieter thanks to its non-touch switches. Nevertheless, our keyboard of the day is still noisier than Corsair’s K65 Pro Mini, which had a second insulating layer as a reminder. Indeed, here the keys tend to click at the end of their stroke. However, the noise remains fairly contained compared to other market references. On top of that, we don’t hear any spring or other noise when typing, which is quite comfortable.
Battery life:
Roccat claims a fairly long battery life for this Vulcan II Mini Air. Indeed, in “work” mode with RGB off, the brand indicates that it will last up to 750 hours. In work and play mode, with brightness at around half brightness, the Vulcan II Mini Air should last up to 150 hours. And finally, in “vacation” mode with heavy keyboard use and RGB at maximum, it would last 90 hours! In any case, that’s a pretty hefty figure.
Unfortunately, in view of the time taken for the test, we won’t be able to give you the autonomy we found straight away. Nevertheless, we’ll update this test when we’ve reached the end of its autonomy. For the test, we’re using it with the RGB at maximum.
RGB:
We end this test section by talking about the RGB present on Roccat’s wireless keyboard. Here, the result is truly beautiful. As usual with Roccat, the RGB LEDs really stand out. Beware, however, of the eyestrain this can cause. Don’t hesitate to lower the brightness a little if the need arises, especially as this will help preserve the keyboard’s battery life.
Nevertheless, it’s important to know that the keyboard is equipped with a technology that enables it to adapt to its use and avoid wasting battery power for “nothing”. In fact, the keyboard is equipped with proximity sensors that know when you’re not using the Vulcan II Mini Air. As a result, when you’re using it, brightness is at its maximum, while when you’re away from it, brightness drops. It updates relatively quickly. In less than a minute of inactivity, the light drops a notch.
[nextpage title=”Conclusion”]
It’s time for our conclusion on the Roccat Vulcan II Mini Air. So, what did we think?
At last, a wireless keyboard from Roccat!
Let’s face it, Roccat’s lack of wireless keyboards has been a real problem until now. Well, that’s no longer a problem! This Vulcan II Mini Air is wireless , and on top of that, it offers impressive battery life (90 hours minimum, 750 maximum). And despite everything, we didn’t detect any loss of connection. This reference is equipped with sensor technology that automatically detects whether you are in front of the keyboard or not. As a result, the brightness adapts to your presence, saving you unnecessary battery drain. It’s a really good idea, especially when you consider the RGB colors that are very present on this keyboard.
Nevertheless, we’re still in familiar territory here, since this Vulcan II Mini Air is a replica of the Vulcan II Mini. It’s still very attractive, aesthetically pleasing and well made. Roccat always equips its Vulcans with premium materials, such as aluminum, and good finishes, and it’s always a success! Beware of the raised feet, which are a little limited for my taste, as the keyboard seemed a little low in use. We also regret that the bundle isn’t rich enough. The days of stickers, extra keys and key-pullers in the box are long gone. And despite the quality of the RGB , it’s a shame that the brand’s software is so outdated. After all, it has changed very little since the very first Vulcans.
This Vulcan II Mini Air features Roccat’s in-house switches. They are highly responsive and pleasant to read. Nevertheless, there are always a few typos at first, as you get used to their responsiveness. Here, unlike the Vulcan II Max, we’re treated to a detachable USB cable that’s slim, sheathed and discreet. As a reminder, that of the Vulcan II Max was thick, rigid and, above all, required two USB ports without the addition of a USB offset.
How much does the Vulcan II Mini Air cost?
Roccat’s new keyboard is available at a recommended retail price of €179.99. That’s 30 euros more than the Vulcan II Mini, which we already found expensive when it came out. It’s starting to sting for a 65% keyboard, even if it is wireless. After all, Corsair is a major competitor here, as the K70 Pro Mini Wireless is available for less, while offering PBT keycaps of its own.
We liked:
  • Its meticulous, aesthetically pleasing design
  • The RGB color scheme
  • This keyboard’s impeccable finish
  • Noble materials (aluminum cover plate)
  • The number of multimedia shortcuts
  • Thin, discreet cable sheath, unlike that of the Vulcan II Max
  • Quiet, pleasant-to-use Titan II switches
  • Finally, a wireless keyboard from Roccat!
  • No loss of connection between PC and keyboard
  • Impressive battery life: 90 hours minimum, 750 maximum
  • Proximity sensors detect your presence and adjust keyboard brightness
We didn’t like :
  • The bundle is not rich enough (no extra keys, key-puller…)
  • Raised legs that don’t raise the keyboard enough
  • The software is a little dated
  • The ever-increasing price!
Roccat offers an aesthetically pleasing keyboard with a meticulous design and impeccable finish. On top of that, the RGB is really bright. Despite all this, the brand continues to equip its keyboards with premium materials (aluminum) and offers high-performance, pleasant house switches. What’s more, we finally find a wireless keyboard from Roccat with consistent battery life. Despite all this, there are still a few shortcomings: a non-existent bundle , aging software and, above all, a price that stings! For us, it’s will be awarded the Silver badge.
Thanks to Roccat!
