GSKill 128 GB Zeta R5 DDR5-6400 CL32:
GSKill has provided us with one of its top-of-the-range kits, the 128 GB Zeta R5 DDR5-6400 CL32. As you can see from the photos, this kit consists of 8 memory sticks, each with 16 GB. As usual, GSKill takes great care with the packaging, and thanks to pre-cut foam pieces, your kit will arrive at your door in perfect tranquillity.
Our kit is clocked at 6400 MT/s with timings of 32-39-39-102, requiring a voltage of 1.40 volts to operate. As you can see, we’re using a black finish with a light gold trim on the top.
The kit is priced at around 1,400 euros. Let’s turn now to our two cooling solutions.
