Review: GSKill Trident Z5 RGB 6400 MT/s CL32
Testing the Intel configuration:
Of course, this kit will only be tested on an Intel platform since our comparisons are made on this configuration from the beginning. However, you can find our articles on the EXPO kits which are tested on AMD cards.
  • Motherboard : ROG Maximus Z690 APEX edition 2022 and Z790 APEX for the OC
  • Processor : Intel i9-12900K Alder Lake and i9-13900K Rocket Lake for the OC
  • Memory : 32 GB GSKill Trident Z5 RGB 6800 MT/s CL34
  • Graphics Card: MSI GT 710
  • Cooling system : Optimus Foundation + 480 mm EK radiator
  • SSD : Western Digital SN850 NVMe SSD M.2
  • Power supply : be quiet! Dark Power PRO 12 1500w
  • Operating system : Windows 10 64 bits
Aida 64 :
Logiciel AIDA64It is a software able to provide you with a lot of information about your configuration but it has the particularity to have a memory benchmark. It will calculate the speed of reading, writing, copying and the latency of your memory kit. It is very often used to compare memory kits between them. It is an excellent tool if you want to compare the performance of your memory kit with those we have already had the opportunity to test.
The version used for the tests is 6.50.2812 beta and we have taken the performance of the previously tested kits.
The performance of this first test seems totally logical to us, with a sixth place obtained. The throughput is unquestionable with an average of 102140 MB/s. This is quite logical since this GSKill Trident Z5 kit combines high frequency with tight timings. The best scores also combine high frequency with tight timings. As a reminder, our best score in DDR4 was 61325 MB/s with the Corsair Dominator Platinum at 4800 MT/s CL19. So, as usual on an Intel platform, you have to focus on frequency and tight timings.
In writing, same observation with speeds which are very good to reach 88423 MB/s. The logic of the graphic remains identical to the previous one. The Corsair Dominator Platinum 4800 MT/s CL19 in DDR4 obtained 67251 MB/s. Once again, we note a logical progression between the different frequencies. The score is better than the Corsair kit since the frequency is identical but the timings are more relaxed.
The findings are identical in copy with again a sixth place for our copy of the day clocked at 6400 MT/s in CL32. The Corsair Dominator Platinum 4800 MT/s CL19 in DDR4 had a copy speed of 57330 MB/s. As you can see, it is in reading and copying that DDR5 takes a very large lead over DDR4.
Finally, the latency. This is the value that all eyes are on because DDR5 is a bit behind. Our best DDR4 kit at this little game was the G.SKill Trident Z Royal Elite 4000 MT/S CL14 which obtained 41.4 ns. You’ll notice that the higher the DDR5 frequency, the narrower this gap becomes. Note that a DDR4 kit in 3200 MT/S CL16 has a latency of 50.3 ns. Here it will be 60.2 ns for our GSKill Trident Z5 RGB 6400 MT/s CL32.
RELATED STORY
Review - Endorfy Liv and Liv Plus Onyx White Wireless
Geekbench 3.4.4:
Logiciel Geekbench 3.4.2This is a benchmark available in several revisions, version 5 having just been released a few weeks ago. It allows you to obtain two scores: one in single and the other in multi. Using this benchmark, we will focus on the performance obtained on the ” Memory Multi-Core ” score which allows to differentiate the memory performance.
The version used for the tests is 3.4.4.
For the Geekbench 3 benchmark, despite the fact that in single core the frequency of our i9-12900K is 5.2 GHz, we note a difference in score between the different memory kits. Once again, it’s a fourth place for this GSKill kit, behind the 6600 and 7200 MT/s kits. For information, in DDR4, our best kit was the G.SKill Trident Z Royal 4400 MT/S CL16 with 5617 points.
In multi core, the gap between our kits is less important. For your information, in DDR4, our best score was 48800. Of course, we have to take into account the DDR5 but also the performance brought by the Alder Lake CPU.
As soon as we isolate the memory score, real differences are visible between the kits. Our kit of the day gets a score of 11134 points! In DDR4, our best kit obtained only a score of 7748 points. Once again, the huge advantage of DDR5 in combination with the Alder Lake processor can be seen.
Geekbench 5.2.5:
Capture Geekbench 5.2.5We decided to add this extra benchmark but why? The CPU benchmark uses new tests that more accurately simulate the tasks that processors face in recent applications. Geekbench 5 also increases the memory used in the benchmark to better reflect the impact of this parameter in the CPU results. For now, we will keep both since version 3 is still widely used.
While in Geekbench 3 we had a difference in single core, here in version 5 the performance is quite identical and it is our kit of the day gets a score of 2013 points.
Finally, the last score of our benchmark series with a total of 19463 points for our GSKill Trident Z5 RGB 6400 MT/S CL32 kit. Again to give you a benchmark score in DDR4, our best score was 11179 points.
In short, as you can see in this series of tests, our sample of the day performs well, but despite its 6800 MT/s frequency, the more relaxed primary timings do not always ensure second place in our rankings.
