The last word:
Even if with the arrival of high frequency kits equipped with Hynix A-die chips, our attention was focused on them, the fact remains that this GSKill Trident Z5 RGB 6400 MT/s CL32 kit proves to be very interesting and very efficient for the price. It is one of the best kits we have had in our hands in M-die thanks to its 6400 MT/s frequency and its tight timings.
The quality of the GSKill chipset is well known and this sample is no exception. If you have an entry-level or even mid-range Intel motherboard, this kit will definitely be an excellent choice. Kits with frequencies higher than 7000 MT/s can sometimes cause stability problems. Even if we have not demonstrated it in this article, it is possible to focus on a frequency of 6800 MT/s and to tighten the timings and subtimings even more in order to increase the scores without having to resort to a memory frequency increase. We are also working on M-die profiles applicable to so-called “entry-level” motherboards.
GSKill Trident Z5 RGB 6400 MT/s CL32 :
We liked:
- The look of the heatsinks with an aesthetically pleasing RGB even if we prefer the black ones
- The quality of finish of the memory modules
- The most powerful DDR5 kit we have had in our hands!
- The excellent overclocking potential of the Hynix B-die chips and the BIOS of our APEX
- A voltage of 1,40 volt which is still very correct
- The lifetime warranty
We would have liked :
- Still a little tighter pricing, but that should happen in the coming weeks
GSKill offers with this Trident Z5 RGB at 6400 MT/s CL32, a very interesting kit with an excellent overclocking potential even with M-die chips. The price of DDR5 continues to fall, so this is a great deal at $189 or 265 euros. The performance with the XMP profile is already very good thanks to the 6400 MT/s frequency and the tight timings. Depending on your motherboard, it will be a piece of cake to go over the 7000 MT/s mark to boost the results even more.
A special thanks to GSKill for making this kit available to us.
![[Tweak League] Tutorial: Overclock your RTX 4060 and get 10% FPS](https://en.overclocking.com/wp-content/medias/sites/4/2024/07/overclocking-gpu-rtx-4060-occ-scaled-218x150.jpg)
![[LAB] Thermal Grizzly’s Mycro Pro RGB LGA 1851 waterblock Le waterblock Mycro Pro RGB LGA 1851 de Thermal Grizzly](https://en.overclocking.com/wp-content/medias/sites/4/2026/04/thermal-grizzly-waterblock-mycro-pro-rgb-intel-1851-presentation-refroidissement-overclocking-15-324x160.jpg)
