Conclusion
We’ve now come to the end of our test of Corsair’s 6500D Airflow. So, good case or not? We tell you all about it!
A heavy, compartmentalized model!
With this 6500D Airflow, Corsair offers us a rather imposing compartmentalized model. Weighing in at almost 17 kg on the scales, this case is anything but light, thanks to the choice of materials based on steel, some of which are very thick, and tempered glass. These can be replaced by wood or aluminum panels for a price ranging from €94 to €125.
Otherwise, this case is in line with the current trend, with different mesh panels to promote air flow in particular.
Internally, there’s plenty of room for the various components that will make up your configuration. Particular attention has been paid to fan compatibility: up to thirteen mills in 120 mm and nine in 140 mm. Nonetheless, there may be a slight lack of compatibility with a 420 mm radiator.
Furthermore, as we have seen, Corsair does not hesitate to offer a range of accessories to personalize its case. These range from alternative wood or aluminum kits to cable trunking.
Assembly: watch out for the HDD cage :
The advantage of compartmentalized cases lies in the space available inside the various compartments. Both on the motherboard side and on the power supply/storage side. However, this case has a minor drawback in the presence of the HDD cage. Indeed, to mount the cooler or run certain cables, you have no choice but to remove it.
On the other hand, the generous rear space makes it easy to group cables into large clusters. Beware, however, of the notches for nylon cable ties, which are few and far between… Or not very accessible once the PSU is in place. Don’t hesitate to pass the clamps through the notches before closing them!
Temperatures within the norm:
As far as temperatures are concerned, the 6500D Airflow keeps our processor and graphics card within perfectly satisfactory limits, despite the absence of a standard fan. If you add fans, you’ll gain precious degrees, especially as the numerous slots will allow you to position your fans advantageously.
As for noise, without fans, this model can only be silent. Finally, bear in mind that this will depend on the mills you choose to integrate. Our advice: don’t choose references that are too fast/noisy, since its average insulation will do little to attenuate their nuisance.
High price:
All that’s left now is to talk about the selling price of $199 or €195 on average, which remains high in absolute terms for a PC case. At this price, we have some serious competition, notably from DeepCool, whose Morpheus we recently tested, a case offering three different chassis layouts, while still being able to offer a trio of basic fans. Alternatively, be quiet! offers the equally formidable Dark Base 701.
It’s up to you to decide whether you prefer the original compartmentalized chassis and robustness of this 6500D Airflow, or whether you prefer the modularity of DeepCool and be quiet!
Corsair 6500D Airflow :
We liked :
- Sober, efficient design
- Control panel with a wealth of connectors
- Simplified side panel opening system
- Compartmentalized case for screw storage
- The wide range of accessories available with this model
- Compatible with BTF and Project Zero motherboards
- Numerous 120/140 mm slots
- Generous rear space for cabling
Our least favorite feature:
- The fact that it arrives without fans
- Lack of 420 mm compatibility
- The HDD cage, which can be a hindrance to wiring and mounting a CPU cooler
- The high price of the case and its accessories
With this case, Corsair offers us a solid reference with excellent capacity. Internally, you’ll have all the space you need to mount your configuration, especially as you’ll have plenty of slots for mounting your fans. Be careful, though, as the HDD cage can get in the way. Last but not least, despite a host of quality features, the price remains high at around €200, hence our silver award.
Many thanks to Corsair!
