The aluminum panel kit
As with the 2500X, this 6500D Airflow also benefits from a dedicated line of accessories. For our part, Corsair has sent us a black brushed aluminum ” Elite Panel Kit ” and a vertical support for the graphics card.
The Panel Kit is simply fitted by unscrewing the steel parts in the case. The parts at the top of the case also have screws at the rear, so don’t forget them.
Then simply realign the new panels and screw them into place, and you’re done.
As you can see, the case immediately takes on a classier, more upscale look . The only drawback is the price ~ €125 for the black and silver aluminum panels. Wooden panels (bamboo, teak and walnut) are more affordable: ~94 €!
