Results:
Let’s now have a look at the results and impressions of this be quiet! DC2 thermal paste. We start with the application of this one, the cross application is quite easy as well as the application with a spatula. The paste spreads without worries.
Results on CPU:
As you can see, this DC2 manages to be among the best thermal pastes we have tested. It will also manage without difficulty to hold under long loads for use on GPU for example. An application on GPU is very easy, because it spreads without worries. So it will be an excellent choice for both CPU and GPU.
The measurements were made with water between 27°C and 28°C and a flow rate of 210 L/h. Here are the details of the best measurements on 3 readings per thermal paste.
It should be noted that due to a lack of thermal paste, the Kingpin Cooling KPX, Noctua NT-H2 and Cooler Master Cryofuze Violet could not be retested with the new protocol. These are noted with a “/” and are grayed out in the results. Compared to the previous protocol with the 12900KS, we have here much smaller temperature differences. However, the best thermal pastes remain at the top of the table. Here is the old table of results on the 12900KS, which gives a greater sensitivity to the previous pastes tested.
