Jonsbo Z20: another ITX case with carrying handle!
New compact case with the Jonsbo Z20, a reference with a carrying handle on top. With this case, the Chinese brand offers us several original colors: pink, orange, black and white, and sometimes a mix!
Jonsbo Z20: a carrying handle and several colors!
Jonsbo Z20With this case, the brand offers us a reference designed to accommodate a micro-ATX or mini-ITX motherboard. This is reflected in its reduced dimensions of 198 (W) x 382 (D) x 335 (H) mm. Weight is also contained, with only 5 kg on the scale.
Even so, the interior space is generous enough to accommodate a 363 mm-long graphics card and a 164 (Intel)/163 (AMD) mm-high CPU cooler. As for the power supply, you can opt for a front-mounted SFX or ATX unit. Beware, however, of the depth of the latter: the larger it is, the more space it will reduce for the graphics card. Finally, unlike DeepCool’s small CH160, we have plenty of room for a 240 mm AIO at the top.
Jonsbo Z20
Last but not least, we’d like to highlight the particularly well-cared-for aesthetics, with a glass side panel echoing the square motif of the front panel. Various colors are also available, with black, white, black/orange, white/orange, black/pink and white/pink casings.
For the moment, the case is not yet available in Europe, at least not to our knowledge. However, it can be found on Aliexpress for over €110.
Here are the Jonsbo product sheets!
