O11 Air mini: Lian Li finally launches its case!
This is it, the wait around the O11 Air Mini from Lian Li is about to end as the brand officially launches its case. The goal of the maneuver is to offer a model with mesh panels to maximize the air flow.
O11 Air mini: the case finally arrives!
Lian Li O11 Air mini As a reminder, this case has the following dimensions: 280 (W) x 400 (D) x 384 (H) mm. Certainly, this may seem imposing, nevertheless, compared to an O11 Air
, it is clearly more compact.
Inside, we find a compartmentalized design with, on one side, the motherboard and the graphics card. On the other, the power supply and storage will take place. Speaking of motherboards, Lian Li announces support for mini-ITX, µATX, ATX and E-ATX models.
For the rest of the components, no particular worries with :
  • 362 mm for the graphics card
  • 170 mm for the CPU cooler
  • 200 mm max for the power supply
The storage part highlights up to six 2.5″ slots for SSD. Otherwise, it will be four 3.5″ slots supplemented by two others in 2.5″.
Lian Li O11 Air Mini
Finally, as far as the cooling part is concerned, this case can accommodate a 360 mm watercooling radiator at the top. At the bottom and in front, the compatibility shows 240/280 mm against 240 mm next to the motherboard. Of course, all this will evolve according to the configuration and the location of the various supports.
As for the price, it will cost 114.90 € in black against 124.90 € in white. A rather affordable price.
This way to the Lian Li datasheet!
