Lian Li V3000 Plus goes white!
Lian Li offers us a new version of an already existing case. The brand offers us, indeed, its V3000 Plus White Edition, a white version of its case released in november 2022. A case as colossal as ever!
V3000 Plus White: the same, but in white!
Lian Li V3000 Plus White
If you are looking for a colossal case capable of accommodating everything, this is clearly the model you need. Indeed, with this reference, the brand offers us something compatible with the most imposing motherboards in EEB format. The same goes for the graphics card, which can reach 589 mm in length on eight horizontal or three vertical slots.
Compatibility for cooling is also exemplary. Inside, up to four 480mm radiators can be installed, plus one 360mm radiator. This leaves a large number of slots for fans: up to sixteen 120 mm mills.
In addition, this case also offers the possibility to turn the motherboard tray to 90°. In this way, the graphics card is suspended, resting on its expansion slots.
Finally, concerning the storage, we find many slots. Up to eight 3.5″ hard disks and eight SSDs or sixteen SSDs can be installed by using the 3.5″ baskets.
For the price, inevitably, it remains high since the case is announced at 549.90 €. Also keep in mind that it will need space since it is a case that measures 279 (W) x 678.5 (D) x 674 (H) mm.
Here is the technical data sheet of Lian Li!
