be quiet! unveils 1300W and 1600W Dark Power Pro 13 power supplies
be quiet! is going all out with new power supplies that are going to be crazy. Indeed, the brand unveils its Dark Power Pro 13 models with powers of 1300W and 1600W. Yes, it’s clearly heavy and it is intended for large multi-GPU configurations!
Dark Power Pro 13 : 1300W and 1600W blocks !
be quiet! Dark Power Pro 13
Here, clearly, with these blocks, we aim at the top of the top, the Rolls of the power supplies. On the one hand, we find quite crazy power, indeed, blocks of 1300W and 1600W, it does not run the streets. Then, we also have the best in terms of performance with 80+ Titanium certified power supplies. As a reminder, this certification ensures efficiencies of 90% at 10% load and 96% at 50% load.
The other element that allows these blocks to stand out is the aesthetics, particularly successful. Here we are dealing with a mesh grid so that the fan can breathe. Otherwise, the casing is aluminum, which brings a little something extra.
Otherwise, internally, the blocks are based on Full bridge + LLC topologies with a fully digital control behind. be quiet! says that this allows its power supplies to offer low noise on the electrical signal as well as excellent power regulation. In addition, these power supplies are compliant with the ATX 3.0 standard.
Otherwise, we will retain the fully modular management of cables with the presence of a sheathing strand by strand. But we will also remember the presence of two 12VHPWR connectors fully supporting 600W of load!
Of course, the price is as high as the services provided by the brand. It will be necessary to count 449,90 € for the model of 1600W and 409,90 € for the version of 1300W!
Click here and here to see the technical data sheets of be quiet!
