be quiet! annonce ses kits watercooling Pure Loop 2 !
We’re off to be quiet! with a new series of all-in-one watercooling kits. The German brand is now offering its Pure Loop 2 kits, equipped with new fans, while remaining on an unchanged base. So, what does this mean in concrete terms?
Pure Loop 2 FX: four radiator sizes!
With this new series of watercooling kits, be quiet! offers us new AIOs with four different radiator sizes. These are available in 120 mm, 240 mm, 280 mm and 360 mm for the largest. Of course, the construction is still in aluminum, while dimensions remain standard at 27 mm thick. However, a fillport is available for topping up with liquid if required.
Otherwise, we still find a pump decoupled from the kit. This is located neither in the radiator nor in the heat sink, but in the tubes. According to be quiet!, this keeps noise levels to a minimum, despite a maximum speed of 5500 rpm.
Ventilation is provided by Pure Wings 3 fans in 120 mm or 140 mm sizes. The 120 mm fans have a maximum speed of 2100 rpm, while the 140 mm fans are a hair slower at 1800 rpm. However, be quiet! doesn’t communicate on their static pressure or airflow, too bad.
We conclude with the announced sales prices, which are €89.90 in 120 mm, €104.90 in 240 mm, €114.90 in 280 and €129.90 in 280 mm. Availability will be effective from October 10, while the warranty will be 3 years.
