True Spirit 120 Rev. B Ultimate: it’s blowing hard at Thermalright!
At Thermalright we announce the arrival of a new ventirad to accompany the True Spirit 120 Rev.B Ultimate. The idea is to take a solid base and add two fans that blow hard.
True Spirit 120 Rev.B Ultimate: a fan with mills that blow quite a bit!
Thermalright True Spirit 120 Rev.B UltimateFor its new cooler, Thermalright offers a heatsink equipped with two TL-C12 Pro mills. The latter, in 120 mm, offer a PWM power supply and an operating speed up to 1850 RPM. At full speed, this duo will generate an airflow of 82 CFM and a static pressure of 2.1 mmH2O. For an aircooling fan, this is really quite a lot!
Especially since the radiator itself is rather interesting. Indeed, it has dimensions of 120 (W) x 48 (D) x 157 (H) mm. Despite its compact dimensions, it has 55 aluminum fins and five copper heat pipes of 6 mm each. The base is obviously made of copper, however, note that the entire block offers a black anodization of the most beautiful effect!
Finally, as many references in the field, we find the usual compatibility of sockets. This model takes into account the LGA-1000 and LGA-2000 from Intel as well as the AM4 from AMD.
We now finish with the price which should be around 80 € which is not cheap for a 120 mm fan!
Here is the technical data sheet of Thermalright !
