HX6210 : a 92 mm fan with six heatpipes from Jonsbo !
We learn that Jonsbo is launching a new and quite particular fan. Indeed, the Chinese brand launches its HX6210, a 92 mm ventirad, a compact model, but with six heatpipes. A very high concentration of heatpipes considering the format!
HX6210: a big concentration of heatpipes for the size!
Jonsbo HX6210 At first glance, one might be tempted to say: “another 92 mm fan”. Of course, the format is not original except for the number of heatpipes. Indeed, where most of the heat sinks in this format have four, here we have six 6mm heat sinks. This allows us to cover the entire surface of the base and therefore, to capture a maximum of heat from the CPU.
Otherwise, this model offers a finish that, at first glance, flatters the retina. We have a top cover with the brand’s logo and a full black treatment. The dimensions, of course, are compact: 92 (W) x 92 (D) x 125 (H) mm. Finally, the base seems off-center, but on the rendering of the photos it is not obvious to determine.
The ventilation is therefore provided by a single fan in 92 mm powered by a PWM signal. At full speed, at 2300 RPM, it will generate an air flow of 45.52 CFM and a static pressure of 2.73 mmH2O. It will be possible to reduce its speed via an adapter L.N.A to make it turn at 1400 RPM.
Jonsbo HX6210
We finish with the compatibility of the sockets which remains usual: LGA-1000 and LGA-2000 for Intel. In AMD, we stay on AM4, classic shall we say. Despite its format, this model seems very capable on paper and it is announced to manage TDP of 210W max.
For the moment, we do not know the price, however, the product specification sheet is online.
This way to the Jonsbo datasheet!
