Zotac unveils three customized RTX 4060!
With the launch of the RTX 4060 just around the corner, information about it is also arriving. Today we learn that Zotac is unveiling its cards. We find a total of three cards, including one model with a single fan. In absolute terms, the cards are quite compact!
Zotac, three rather compact RTX 4060s!
Zotac RTX 4060 SoloAmong the three cards offered by the brand, one model catches our eye: the 4060 Solo. In fact, it’s an ultra-compact version equipped with a reduced heatsink. As you can see, it features a single fan, while offering a classic dual-slot format. Clearly, this is a small card that will fit into any case, even ITX models!
However, it’s also a so-called ” MSRP ” card. In order to meet NVIDIA’s advertised price, this model dispenses with the backplate, for example, or takes advantage of reference frequencies. The boost reaches 2460 MHz.
With this, we find two other cards with the Spider Man and Twin Edge versions. These two versions feature a slightly larger heatsink with two fans. However, these are models that will always occupy two slots in a case, which is good news.
Finally, the operating frequency shows a slight factory overclocking. In boost mode, the Spider Man model runs at 2475 MHz, compared with 2490 MHz for the Twin Edge version.
As for prices, we remind you that the official retail price of the 4060 is around €330-335. It remains to be seen how much the Twin Edge and Spider Man models will cost!
Here are the Zotac product sheets!
