Toughfan EX Pro: fans with magnetic connectors from Thermaltake!
Thermaltkae is offering us new fans and, surprise, all without superfluous RGB lighting. The Toughfan EX Pro is the ideal solution, with a magnetic connector.
Toughfan EX Pro: magnetic connectors for Thermaltake!
Thermaltake Toughfan Ex ProThermaltake’s new fans feature frame-mounted connections. Here, we find a magnet system for easy installation. Of course, the connection can be made in series, limiting the number of cables in the installation!
The fans are available in 120 and 140 mm sizes. Their blade profile is similar to that of the brand’s Toughfan fans. What’s more, these blades are also interchangeable with a ” reverse ” set for installation in the bottom of a case, for example. The aim is firstly, to facilitate cleaning, secondly, to avoid (too much) loss of performance, and thirdly, to enhance aesthetics by masking the blades.
In terms of features, we have :
  • 120 mm:
    • Speed: 500 to 2000 rpm
    • Air flow: 70.8 CFM
    • Static pressure: 3.19 mmH2O
  • 120 mm reverse:
    • Air flow: 64.21 CFM
    • Static pressure: 2.60 mmH2O
  • 140 mm :
    • Air flow: 119.6 CFM
    • Static pressure: 3.57 mmH2O
  • 140 mm reverse :
    • Air flow: 102.3 CFM
    • Static pressure: 2.95 mmH2O
Thermaltake Toughfan Ex ProAll that’s left is to talk about sales prices, which are $89.99 in 140 mm in a three-pack, versus $79.99 in 120 mm, also in a three-pack.
Thermaltake’s product sheets are here!
