Review: Lexar ARES RGB 6400 MT/s CL32
The importance of the XMP profile:
BIOS settings:
We can’t stress this enough, but your memory kit ‘s parameters are not automatically set after you’ve installed it. If this is the case for your processor, it’s not so for your memory kit, and you’ll have to go through the BIOS! That’s what we had to do with our Z690 APEX to get the BIOS to load the XMP profile.
You can then configure it manually, choosing the right frequency, timings and voltage for your kit. For ease of use, we advise you to enable XMP (Intel) or DOCP (AMD) mode in ” AI Overclock Tuner “, so as to set it up automatically.
Without this, your performance will be impacted in all areas, and you’ll end up with a kit that doesn’t exceed the CL40 frequency of 4800 MHz. Performance will then be extremely limited. So let’s activate our XMP profile directly in the BIOS.
ASUS BIOS, whether on the APEX or Crosshair models, benefit from memory profiles. They are a good basis for overclocking your memory kit. We’ll start by using them in our overclocking tests. Our kit is now set up in the BIOS and will work with the manufacturer’s specifications.
As you can see from the screenshots above, once the XMP profile has been activated, the settings are automatically detected. The frequency is set to 6400 MT/s, timings 32-38-38-76 are activated and the voltage is increased to 1.40 volts.
