Home Reviews CPU & RAM Review: Intel Core Ultra 9 285K and Ultra 5 245K
Overclocking.com video
7-Zip 19.0:
7-Zip 19.0:
This benchmark is an integral part of the Benchmate software, which we also use for Cinebench tests. The advantage of this tool is that it is validated by Hwobt and can therefore be used to encode your scores directly onto the platform.
7-Zip, as its name suggests, is a file compression and decompression benchmark. You can either use the one available directly in the 7-zip utility, which will give you a compression score and a decompression score. Here, with 7-Zip 19.0, the result is an overall score that takes into account compression and decompression performance. Here too, Benchmate is free, so you can evaluate your score with your configuration.
The score obtained with our Intel Core Ultra 200S does not seem to reflect reality. These may not be correctly supported by the benchmark. We are waiting for confirmation as to whether or not we will be keeping this benchmark in the future.
