[nextpage title=”Modularity”]
Unveiled at CES 2026, the Cooler Master MasterFrame 360 Stage LCD adds a 15.6-inch display and a stand to the brand’s FreeForm 2.0 structure.
After giving you a detailed overview, we’ll now focus on its modding andcustom water-cooling capabilities. We’ll also take this opportunity to give you an exclusive look at the new Alphacool monoblock, as well as the new Apex Grip line of fittings.
MasterFrame 360 Stage LCD: Modularity?
The entire Cooler Master FreeForm 2.0 lineup promises high modularity and naturally appeals to modders and enthusiasts ofcustom builds. The aluminum frame is perforated throughout, offering great versatility for mounting components. And if the original mounts aren’t enough, 3D printing can easily be brought into the mix.
A Must-Have
But the 360 Stage LCD stands out. While it retains the basic external structure, the addition of the stage and the front display has significant implications. The chassis is much more visually imposing than the original model. Inside, we find a central compartment for cable management. While practical, this layout requires a specific distribution of space among the compartments, forcing the graphics card to be installed vertically. The brand has made this choice deliberately, aiming to position this chassis primarily as a showcase model. The 5.0 riser is included. GPUs of all sizes are supported (up to 430 mm), and a mounting bracket is provided. The MasterFrame’s high level of modularity is thus clearly compromised here in favor of visual impact.
Radiator and Fan Mounts The Stage LCD’s adjustable mounts can accommodate, both at the top and bottom:
- 6 120 mm fans
- 2 140 mm fans
- 2 180 mm fans
- 2 200 mm fans
When it comes to radiators, things get a bit more complicated. We can easily install 400 mm, 2×180 mm, 280 mm, or 360 mm models. The mount for six 120 mm fans might suggest the possibility of placing two 360 mm radiators side by side. That’s not the case. Only the slimmest models will fit (scratches guaranteed). A few extra millimeters in width would have been welcome to allow for this option. We’ll also need to take the thickness constraint into account : 75 mm for the entire radiator and fan assembly.
Motherboard The case supports motherboards up to ATX format, including BTF, andair coolers up to 145 mm.
Reservoirs and Pumps
When it comes to installing water-cooling pumps and reservoirs, you’re spoiled for choice. In the front chamber, the simplest solution is to mount the reservoir on a fan (either at the bottom or the top). But it’s also tempting to drill a hole in the cable cover to the right of the motherboard to mount a tube reservoir or an FLT 120. In fact, this plate is easy to remove so it can be drilled outside the case.
And the rear compartment isn’t left out either. It’s far too spacious to be used solely for cable management. It’s therefore possible to install one or more reservoirs or top-mounted pumps there. The only limitation to consider will be the length of the power supply and the cables or hubs that need to be managed.
[nextpage title=”Our Setup”]
For our build in the Cooler Master MasterFrame 360 Stage LCD, we’re turning to the custom water-cooling brand Alphacooland their new lines of monoblocks, radiators, and fittings. This will also be an opportunity to introduce them to you. And there’s a lot to say.
An AMD Build
AMD takes center stage, as Alphacool all-in-one coolers are only available for motherboards from the “Red Team.” We’ve chosen the ASUS ROG STRIX X870-F Wi-Fi motherboard and paired it with the renowned Ryzen 7 9800X3D. This processor needs no introduction—it’s the gaming king of this generation.
We’re pairing it with the Radeon RX 6900 XT LC reference graphics card. This is a rare variant of the RX 6900 XT, featuring AMD’s reference design and originally equipped with a 120mm AIO produced by Cooler Master. Keeping this AIO, as a nod to Cooler Master, would have been interesting, but we’re installing a 1-slot Alphacool water block because we want to build a custom setup.
The RAM and SSD are provided by Biwin. Finally, the power supply is a Cooler Master Elite Gold 1000 model.
Alphacool Water Cooling: A Flurry of New Releases
Alphacool has been rolling out announcements at a breakneck pace since EKWB’s decline. And we’re not complaining, as innovation and boldness seem to be at the heart of the German brand’s current strategy.
Monoblock
As a reminder, a monoblock is a water-cooling radiator capable of cooling multiple components on its own. Highly popular and synonymous with high-end systems, they were regularly included as standard on motherboards from major brands. Think of the Waterforce series from AORUS, Glacial from ASUS, or Aqua from ASROCK. The Z890 and X670 generations saw their near-total disappearance, in favor of more traditional systems. But Alphacool doesn’t see it that way and offers a relatively wide range of models. It’s important to note that, in most cases, a monoblock is compatible with only a single motherboard model.
The X870 series monoblocks feature:
- CPU, VRM, and first M.2 slot cooling
- Retains the original I/Oshield and RGB lighting and/or display (for Crosshair)
- Optimized water flow over the hotspots of AM5 processors
Core XT45 Aurora Radiator
A purely aesthetic evolution of the brand’s XT45 radiators, they feature a new design highlighted by a magnetic RGB strip. This strip can be installed on either side of the cooler. The cooler’s appearance is a matter of personal taste. In our opinion, it integrates perfectly with the Stage LCD. However, its overall width prevents two from being installed side by side on the rails.
Apex Grip Fittings
A small revolution at Alphacool: this new line of fittings stands out clearly from previous generations:
- A completely different form factor —wider—with a notable design focus
- Grip for easy handling and installation
- Sealing mechanism similar to the Eiszapfen Proseries for rigid tubing
- Multiple modular adapters, including a double-rotating offset adapter
Reservoir For the reservoir-pump assembly, we’re using the 150 mm version of the Eisbecher Aurora D5 Acetal model. It will be mounted in the rear compartment.
Fans
Once again, we’re relying on Alphacool’s Apex Stealth Metal fans, here in the RGB version. These 120 mm fans, equipped with a metal frame, come at a premium price but are well worth it thanks to their high-end performance, unique design, and positioning. They are best reserved for show case builds and very high-end systems.
[nextpage title=”Installation and Verdict”]
Monoblock Installation
Installing the Alphacool monoblock on the ASUS ROG STRIX X870-F Wi-Fi motherboard is a breeze. The included user manual is precise and detailed. We walk you through the process in the video below. The main steps are:
- Installing the CPU
- Installing the SSD in the first slot without reattaching its heatsink
- Removing the ILM and the original cooler mounts
- Removing the VRM heatsinks and the I/O shield
- Applying thermal paste and thermal pads (included and pre-cut)
- Securing the original I/O cover to the monoblock
- Positioning and tightening the monoblock
The result is striking and evokes the golden age of monoblocks in custom water cooling. The block integrates perfectly with the rest of the motherboard. We’d even go so far as to say that it adds a real touch of character to this model, which had been struggling to find its place in the ASUS lineup.
The Radiators: Not So Simple
Cooler Master’s FreeFrom 2.0 design stands out, among other things, for its heatsink/fan mounting system. It offers a wide range of adjustment in two dimensions, but it achieves this by drilling a multitude of holes into the aluminum structure—where most brands prefer to install rails. This choice makes installation relatively time-consuming and tedious, especially when you want to try out several different configurations, multiple radiators, and so on. However, in our opinion, it’s ultimately an excellent choice. In fact, a major advantage over rails is that once the components are installed, they are securely fastened, perfectly aligned, and won’t budge a millimeter, even during transport. This is a major asset when designing a custom loop with rigid tubing.
So, after some initial trial and error, we were pleased to find that our top and bottom radiators were perfectly aligned. We had actually connected them with a single rigid tube at first (an option we didn’t use for the final loop).
Maximum Thickness
A note on thickness. The combined radiator and fan assembly must not exceed 75 mm. In practice, we’ll aim to limit it to 70 mm (which is what we did here), especially if the radiators are installed on the front side of the case. At 75 mm, there’s a high risk of contact with the CPU cables at the top and the graphics card at the bottom. In fact, we weren’t able to use the 5.0 riser provided by Cooler Master. It was too thick at the bottom and came into contact with the fans. We replaced it with a less bulky ASUS model.
Overall, installing the radiators is no walk in the park. Between the time-consuming assembly and disassembly, limited accessibility at both the top and bottom (mainly due to the central structure), and thickness restrictions, you have to juggle these constraints. It’s ironic for such a large case. On the other hand, once you’ve found the ideal setup, the result is more than satisfying: rock-solid mounting, with the radiators, fans, and tubes prominently showcased.
Fittings and Tubing: A Pleasant Surprise
After struggling with the radiator installation, we were relieved to try out the new Apex Grip line. There’s almost nothing to criticize about these fittings. The tension on the swivel models is ideal. The rubber ring is indeed a plus for grip and tightening. Above all, the sealing and clamping mechanism on the rigid fittings is perfect. It inspires confidence and automatically ranks among the best in its category.
If we had to point out any flaws, we’d note that these are among the widest models on the market. We would definitely not recommend them for SFF builds. In that case, the Thermal Grizzly line is a much better fit. By way of comparison, the Apex Grip clamping rings are as wide as those on Optimus’s 10/16 flexible models, and the dual-rotating offsets match the dimensions of EKWB’s new-generation models. Finally, the clamping system for the flexible fittings may prove too aggressive depending on the type of 10/16 mm tubing chosen: it grips the tubing too tightly and too early, causing it to rotate while the ring is being tightened. Once tightening is complete, the tube slowly returns to its original position… and loosens the fitting on the opposite side. In this (rare) scenario, you must hold the tube in place while tightening.
The Custom Loop
The initial plan included two loops. In addition to the Eisbecher, we planned to add a reservoir-less top-feed pump above the feedline. Ultimately, we opted for a single loop for the sake of simplicity, but made sure to keep the dual-loop option open in case we wanted to go back to it later. To do this, the rear chamber contains only flexible tubing. Specifically, we removed the rigid tube that connected the two radiators and replaced it with an oversized flexible tube. In fact, all it will take is disconnecting it and connecting it to a pump head to switch to a dual-loop setup, without even having to cut it to size.
At the front— since this is a showcase build— the tubes will be rigid and must be perfectly aligned. This poses no particular difficulty, thanks to the precise positioning of the radiators via FreeForm 2.0. All that remains is to ensure communication between the front and rear chambers. Once again, the MasterFrame 360 Stage LCD simplifies the task. The decorative metal plate separating the chambers can be removed without tools. So we drill the holes outside the case, install Alphacool low-profile bulkhead fittings,and put the plate back in place.
The result: a loop that looks minimalist but is scalable as needed. We fill the loop with colored coolant to make the tubing stand out… and move on to the Stage.
MasterFrame 360 Stage LCD: Screen and Stage
You’ll either love it or hate it. In any case, this front-mounted Stage is the ultimate expression of a showcase build. It’s complemented here by a display with a simple function: it’s connected to the motherboard via an internal USB cable and features physical buttons beneath the chassis. A shortcut (center + right buttons) switches it to storage mode. It then appears in the list of USB devices. The folder contains the driver for configuration and allows you to transfer files to display (JPG or MP4). The screen can then be used as a slideshow with those files or as a secondary display. You can switch between modes directly using the buttons under the chassis.
MasterFrame 360 Stage LCD: Verdict
The MasterFrame 360 Stage LCD is a real oddball, even within the FreeForm 2.0 lineup. It’s a mixed bag. As spacious as it is restrictive in places, as satisfying as it is frustrating, it’s definitely intended for modding, and we recommend it for that purpose. But it requires careful planning in certain areas… while being extremely flexible in others.
In and of itself, it’s a bold product that pushes boundaries, experiments, and isn’t afraid to impose its own constraints. It divides opinion, but has already sparked a trend. In fact, our latest trip to Taiwan for Computex 2026 allowed us to observe that many brands are interested in this trend. The majority of the “case” booths we visited featured at least one model equipped with a “stage” designed to display a figurine (some even had several).
As for the new Alphacool lineup and its monoblock: it’s a flawless release that confirms the momentum the brand has built over the past two years. The worlds of modding and custom water cooling seem to be experiencing a burst of creativity after a long slumber—stay tuned.
