NZXT announces via its press release the upcoming arrival of its N7 Z790 motherboard. Recently, we tested the N7 Z690 in DDR4 and we were waiting to see a DDR5 version. This is now the case with the new N7, built around Intel’s new Z790 chipset. This NZXT N7 Z790 will of course be compatible with Intel’s new 13th generation Raptor Lake processors. It will also support 5th generation PCIe and DDR5.
We find the design that makes the reputation of the brand with a version protected by a sleek metal cover. This N7 will be the best combination with the NZXT H series cases. In addition, the N7 Z790 allows you to control the curves of your fans and connect RGB fans or LED strips and customize their lighting using the NZXT CAM software.
On the power stage side, we are on 16 + 1 + 2 phases. If we refer to the last NZXT motherboards, we should still be on a collaboration with ASRock for the PCB of this Z790. The availability is scheduled for the fourth quarter of this year and for a price of 299$. We should propose you its test when it will be available.
