Kolink’s Unity range is expanding!
The Kolink brand announces new cases in its Unity series. These are none other than the Meshbay and Peak models, versions in tempered glass and mesh for enhanced breathability. As usual, prices are accessible to all. We’re talking €95 for the most expensive model.
Peak and Meshbay, two cases completing the Unity series!
Kolink PeakFor the moment, the brand’s technical specifications are not yet available online. However, we can already tell you that the Peak model clearly emphasizes tempered glass. This reference offers two glass panels on the front and side. The aim is clearly to provide a clear view of the machine’s interior.
In terms of components, these two models adopt a mid-tower format that can accommodate an ATX-format motherboard. As for the graphics card, we have a space 40 cm long. All that remains is to find out what restrictions apply to the power supply or CPU cooling unit.
Kolink Unity Meshbay
On the other hand, we have the much more discreet Meshbay models. Note that the aRGB version of the case has a tempered glass side panel, while the other version has a mesh side panel. In any case, this is a version that focuses more on cooling performance than anything else.
Finally, as far as ventilation is concerned, these new cases will benefit from Umbra Void Pro fans. It remains to be seen whether they will indeed arrive with four mills, as the visual suggests.
The price should be acceptable, since the Peak model is priced at €94.90. On the other hand, the Meshbay aRGB is priced at €84.90, compared with €64.90 for the non-aRGB version. The fan costs €12.90/piece.
