Gelid AIO Liquid Series kits in 120 mm and 240 mm
Gelid announces two new watercooling kits in 120 mm and 240 mm. They are part of the Liquid Series range of the brand. They offer a temperature display as well as RGB in abundance!
Liquid Series: RGB and a temperature display on the pump!
Gelid Liquid Series 120 mmWith these kits, the brand offers us a relatively small AIO considering the current standards (360 mm or 420 mm). Indeed, we only have two kits in 120 mm and 240 mm. However, this does not prevent the brand to bet on the RGB with a lighting present on the pump and fans with an infinite mirror effect.
Nevertheless, the little feature that makes us happy is the real-time display of the temperature and the speed of the fans on the pump. It remains to be seen if this will be readable with the infinite mirror effect.
Gelid Liquid Series 240
Despite everything, we remain on classic kits with an aluminum radiator of 27 mm thick. Concerning the pump, it works at 2600 RPM. Finally, we find fans running from 750 RPM to 1800 RPM. At full speed, the static pressure will be 1.67 mmH2O, but the air flow is unknown. Finally, we have compatibility with AM5 and LGA-1700 sockets !
On the other hand, we must admit, they will not cost much: $66 the 120 mm model against $85 the 240 mm.
Here and there are the technical data sheets of the brand!
