Fluctus 120 PWM aRGB: bright SilentiumPC fans!
Last June, the Polish brand SilentiumPC announced its Fluctus fans in 120 mm. Since then, these fans did not have RGB lighting, however, the brand corrects this mistake. Indeed, the company unveils its Fluctus 120 PWM aRGB, fans now illuminated.
Fluctus 120 PWM aRGB: the fans come with bright lighting!
SilentiumPC Fluctus 120 PWM ARGBClearly, this new version has the same shape as the original Fluctus. We have a mill in 120 x 25 mm square shape with nine serrated blades. However, they become translucent in order to help the diffusion of the lighting, generated at the level of the central hub.
As with the unlit version, airflow and static pressure figures are not known. However, we do know that these mills will run from 300 RPM to 1800 RPM. Similarly, they offer a semi-passive operation up to 10% PWM signal and will stop when this signal reaches 5%.
The connection is quite simple since it consists of two cables: one for the lighting, the other for the power supply and the PWM signal. You should also know that there is a male and female connector on each of them.
In short, it is difficult to say more without having all the information. However, SilentiumPC boasts a 6-year warranty like Arctic and Noctua for example.
Here is the SilentiumPC datasheet!
