Ryzen 9700X and 9900X also on Cinebench r23
After the Ryzen 5 9600X leaks on Cinebench R23, it’s the turn of the Ryzen 7 9700X and Ryzen 9 9900X to show their faces on the @9550pro Twitter account once again.
I’d like to remind you that we have no information on whether the CPU is overclocked or not, nor on the motherboard used, the RAM or the cooling system. So this information should be taken with a pinch of salt.
The Ryzen 7 9700X is a chip with 8 physical cores and 16 logical cores (threads), while the Ryzen 9 9900X is a processor with 12 physical cores and 24 logical cores (threads).
According to the leak :
  • The Ryzen 7 9700X would achieve a multi-core score of 21.533 points and a single-core score of 2.280 points.
  • The Ryzen 9 9900X, meanwhile, is said to score 32.216 multi-core points and 2.232 single-core points.
We’re talking about a 14-15% gain in single-core performance for the 9700X and 9900X over their predecessors, since the 9700X and 9900X score around 2,000 points in single-core on Cinebench R23.
Multi-core scores also improve, with a 16% improvement for the 9700X, which scores around 18,000 stock points without overclocking, and a 14% improvement for the 9900X, which scores around 28,000 points.
But as we said before, this should be taken with a pinch of salt, since with overclocking of older generations, we’re getting very close to the leaked scores. Zen 5 with Ryzen 9000 is not a revolution, but rather an evolution of Ryzen 7000.
As a reminder, the release of Ryzen 9600X and 9700X has been pushed back to August 8, while Ryzen 9900X and 9950X are now scheduled for August 15.
