Home Reviews Cooling Review: NZXT Kraken 240 RGB
Overclocking.com video
The AniME Matrix panel
Now it’s time to see what NZXT has in store for us with its famous software: CAM. With this software, you will be able to fully customize your watercooling kit and adjust the speed of the pump or the fans as you wish. The same goes for the screen customization. Anyway, to get it, go to the following link.
Once installed, if you want to adjust the speed of fans / pump, it remains only to go to the cooling tab. There, two elements are displayed: the pump and the fans. Simply click on the element you wish to configure and apply either one of the pre-established profiles or customize its curve. The different points will be moved according to the temperature and the desired speed.
Finally, to take control of the screen and the RGB lighting, we must go to the lighting tab. There, just in front of ” LCD Display “, you can select the display style for the screen. Finally, various customization options are available such as the color, the target probe to scan for values, etc. There is even an “Image” option through which you can display a personalized .jpeg, but no .gif support. As for the fans, you just have to click on the corresponding part to customize the colors of your fans.
NZXT Kraken 240 RGB White écran
Clearly, the screen is not at the level of its elite counterpart. The luminosity is at half-mast since during our photo shoot , to see something, we had to make sure that there was no reflection at the pump. So be careful with the ambient light or you won’t see much. It’s a bit of a shame.
