From DeepCool, we learn that the brand launches a new series of power supplies. Indeed, we can now count on the PQ-M Series models. A range of four power supplies with powers between 650W and 1000W.
PQ-M Series: four blocks from 650W to 1000W fully modular!
As we said, the brand offers four power supplies of different powers. In the program, we find 650W, 750W, 850W and 1000W for the biggest model. However, high power does not necessarily rhyme with bulk since these power supplies show a reduced depth of 14 cm.
From a design point of view, we have something quite sober with rounded edges. The same goes for the different grilles which have a square pattern.
The cable management will be fully modular, leaving you the possibility to connect only the necessary connectivity. However, keep in mind that the 1000W model only comes with three PCIe 6+2 connectors. If you need more, you’ll have to ask the brand for a total of 6 connectors for free. To do this, you’ll need proof of purchase and to make the request before March 31, 2022.
Internally, we have a 120mm fan with FDB bearing. It offers a semi-passive mode of operation up to 30% load via a button on the back of the casing.
Otherwise, from an electrical point of view, these references have an 80+ Gold certification and a single 12V rail. In the same way, we have the right to Japanese capacitors and the following electrical protections: OPP, OVP, SCP, OTP, OCP. Finally, we have blocks with a full bridge LLC design with a DC to DC converter and an active PFC.
In terms of pricing, the brand announces:
- 650W : 99,99 €
- 750W : 109,00 €
- 850W : 129,00 €
- 1000W : 159,00 €
The whole thing also comes with a 10-year warranty.
Here is the technical data sheet of DeepCool l
