Luxlim: a low profile Cougar keyboard with optical switches!
Cougar launches a new keyboard on the market, the Luxlim. It is a low profile model equipped with optical switches and an aluminum construction!
Luxlim: a keyboard of only 20 mm height!
Cougar Luxlim With this new model, the brand offers us a standard keyboard format called “104 keys”. This one also offers a neat construction, especially thanks to the presence of an aluminum layer plate. On the other hand, the keys seem to be made of ABS, a basic plastic material in the field.
The keyboard has low profile optical switches. Two feelings are proposed with linear and cliky. Of course, the reactivity will be required with a point of emphasis located at 1.7 mm on a total stroke of 3 mm. On the other hand, the linear will require a force of 55g for the activation against 60g for the clicky.
This model also offers some good ideas like a detachable USB type C cable. The elevation legs are magnetic, at least, no risk of breakage! And on the lighting side, we have the right to an RGB present under the base of the keyboard.
The bill is 119 €, if you like low profile keyboards the 20 mm height of this reference should satisfy you.
This way to the Cougar technical data sheet!
