Lian Li’s Uni Fan SL Infinity is now 140mm!
In June 2022 in the past, Lian Li proposed its Uni Fan SL Infinity fans, but in 120 mm. Now, we move on the format above with mills that display 140 mm of side. Moreover, they continue to benefit from the improvements of this series.
Uni Fan SL Infinity, the fans are going to 140mm!
Lian Li Uni Fan SL Infinity 140Let’s get to the heart of the matter with the technical characteristics of this version. Thus, the brand offers fans operating at rather reasonable speeds. The rotation range is from 0 RPM to 1600 RPM. At full speed, the air flow will reach 72.7 CFM while the static pressure will rise to 2.88 mmH2O. That’s it.
Now, as we can see, on the lighting side, it’s a party in the village. The RGB is present on the central hub, on the sides of the frame and via edgings on the frame itself. The little bonus is the infinite depth effects present here and there.
Nevertheless, what is interesting here is the way the fans are connected since they can be connected in series through their frame. Also, unlike the first models of the series, the compatibility with watercooling radiators has been improved.
As for the price, it will cost $29.99 in the United States per unit only. Unfortunately, this does not give access to the controller, which is essential to drive the fans.
This way to the Lian Li datasheet!
