Endorfy releases a stunning ARX 700 White ARGB
We regularly talk to you about Endorfy products, which have won us over with their excellent value for money. But in the chassis range, a white reference was missing. Well, we can’t complain any more, because at Computex, the brand has just unveiled a superb ARX 700 White ARGB.
The ENDORFY Arx 700 White ARGB is a case that promotes air circulation, with a large mesh front panel. It is equipped with four Stratus 140 White PWM ARGB fans. Three are at the front, one at the rear. They ensure optimum airflow and silent operation. The PWM control adjusts the speed according to the load. This ensures efficient cooling.
Ventilation and protection: Front and top panels promote air circulation. A removable dust filter at the bottom protects components. Easy access simplifies cleaning and maintenance.
Space inside
This case accepts graphics cards up to 410 mm and power supplies up to 340 mm. Seven fans, CPU coolers up to 179 mm and radiators up to 360 mm can be installed. It is compatible with ATX, microATX and mini-ITX motherboards, with seven expansion slots.
Design and cable management
This is ENDORFY’s first all-white enclosure. Tempered glass highlights the interior. White (and optional black) rubber grommets make for easy storage. This improves aesthetics and airflow.
ARGB lighting
Stratus 140 fans feature customisable ARGB lighting. An integrated controller lets you adjust the effects via a dedicated button. You don’t need a compatible motherboard to enjoy this feature.
I/O panel
The front panel includes two USB-A 3.2 Gen 1 (5 Gbps) ports, one USB-C 3.2 Gen 2 (10 Gbps) port and two 3.5 mm audio jacks. This ensures modern, practical connectivity.
Availability
The ENDORFY Arx 700 White ARGB is now available for pre-order. The official release date is June 16. It combines cooling, style and compatibility with high-end components. The retail price is €125 including VAT
The ENDORFY Arx 700 White ARGB case in detail:
  • Product code: EY2A017
  • EAN: 5903018668482
  • Product type: PC case
  • Color: white
  • Dimensions (H×W×L): 486×228×472 mm
  • Motherboard form factor: ATX, microATX, mini-ITX
  • Graphics card clearance (GPU): 410 mm
  • CPU cooler clearance: 179 mm
  • Power supply clearance: 340 mm
  • Expansion slots: 7
  • Number of bays:
    • internal:
      • 1× 2.5″/3.5″
      • 6× 2.5″
    • Cooling system:
      • Maximum number of fans: 8
      • Number of fans included: 4
        • Front: 3× Stratus 140 White PWM ARGB fan (200-1200 rpm)
        • Rear: 1× Stratus 140 White PWM ARGB fan (200-1200 rpm)
      • Radiator compatibility:
        • Front: 1× 120, 240, 280, 360
        • Top: 1× 120, 240, 280, 360
        • Rear: 1× 120, 140
      • Dust filters:
        • Front
        • Top
        • Bottom
      • Front I/O:
        • 1× USB-C 3.2 Gen 2 (up to 10 Gbps)
        • 2× USB-A 3.2 Gen 1 (up to 5 Gbps)
        • 1× headphones (minijack 3.5 mm)
        • 1× microphone (minijack 3.5 mm)
        • 1× POWER button
        • 1× RESET button
