A Reddit modder suggests an RTX 4070 Ti ITX!
The big problem with today’s RTX 4070 Ti is that none of the models offers a small footprint. And when you don’t have a lot of space on your desk, that makes it hard to build a high-performance mini-ITX machine. Fortunately, on Reddit, a user (@TechTaxi) has put together an RTX 4070 Ti ITX for us!
RTX 4070 Ti ITX: a rikiki card!
RTX 4070 Ti ITXYes, you’re looking at an NVIDIA 4070 Ti, which has been greatly reduced in size. In fact, this model, still in the prototype stage, offers a reduced footprint with a length of 17.3 cm and a thickness of just two slots.
As you can see, the card features just a single fan mounted on a reduced-size aluminum radiator. As for the fairing, it’s hard to say whether it’s been salvaged from another board or is the result of 3D printing.
However, as far as we know, this board has been designed to fit into a Velkase Velka 3 case. This is a ridiculously small case, offering an internal volume of just 3.81l. However, the user hasn’t yet had time to carry out tests to check temperatures, obviously too busy creating a dual-slot RTX 4080.
In any case, given the heatsink, undervolting will certainly have to be applied, especially when we know that the TDP of this GPU is 285W.
