Silverstone reveals its IceMyst AIOs with plenty of fans
One of the new products Silverstone presented at Computex was the brand’s IceMyst AIOs. As a reminder, their distinctive feature was a pump on which numerous additional fans could be mounted. Well, the series has now been officially announced by Silverstone!
IceMyst: Silverstone announces its AIOs with modular pump fans!
Silverstone IceMyst 360
The brand’s kit comes in a range of sizes, with 240 mm, 280 mm, 360 mm and 420 mm radiators for the largest. While the radiator benefits from aluminum construction and is 27 mm thick, there’s more to say about the pump.
Silverstone IceMyst pompeIn fact, the pump is rather unusual in that it can be fitted with additional fans. The aim is simple: to cool everything around the socket. Several fans can be installed to cool key areas of the motherboard, such as VRM, RAM or an M.2 SSD. The advantage of this solution is that it’s plug & play and can be rotated through 320°.
These additional fans measure 70 mm in diameter and operate from 500 rpm to 2800 rpm. In terms of air flow, they generate 17.2 CFM and a static pressure of 2.0 mmH2O.
Silverstone IceMyst
Finally, main ventilation will be provided by two or three 120 or 140 mm fans with the following characteristics:
  • 120 mm :
    • Speeds: from 500 rpm to 2200 rpm
    • Air flow: up to 75.74 CFM
    • Static pressure: up to 3.4 mmH2O
  • 140 mm :
    • Speeds: from 450 rpm to 1750 rpm
    • Air flow: up to 93.29 CFM
    • Static pressure: up to 2.39 mmH2O
All that’s left now is to find out the prices, and we have to admit we’re quite curious!
Here are the Silverstone product sheets!
