RTX 4070 Ti Windforce OC: an entry-level card for Giga
At gigabyte, we already find a number of 4070 Ti custom with a total of six cards… If we omit the revision of the Eagle version of course. Anyway, a seventh version has joined the page of the brand’s website. This is the most affordable version with the RTX 4070 Ti Windforce OC.
RTX 4070 Ti Windforce OC: the most affordable model from Gigabyte!
Gigabyte RTX 4070 Ti Windforce OCWith this card, Gigabyte offers us a rather “basic” model. Indeed, it is a rather simple reference since it does not have RGB lighting on the one hand. On the other hand, the radiator is more basic than on an Aorus model for example. Here, the fans are simpler, there is no vapor chamber and the fins seem to offer a simpler cut.
However, this does not prevent the brand from opting for a thick heatsink with a large copper base. In addition, a total of eight copper heat pipes are present to route the heat through the heatsink.
Be aware, however, that we are talking about a factory overclocked card, but nothing to jump up and down about. The boost only offers a small gain of 15 MHz, just enough to put the OC logo on the card.
Otherwise, the connectivity remains standard with the presence of three DisplayPort 1.4a and one HDMI 2.1a. As for the power supply, we find the famous 12VHPWR in 12+4 pins.
It only remains to know the price since the card does not seem to be available on the market yet.
Here is the Gigabyte datasheet !
