The last word:
Useful? In the end, not really for most users, except, as in our case, for graphics card testers. Unfortunately, in order to be able to respond to the different scenarios, we would need to have each model of the WireView available in order to respond to the different power supply solutions offered on graphics cards (1×8-pin, 2×8-pin, 3×8-pin and 12VHPWR, all in normal and reverse versions). And then the bill would get very high.
Now, if you have a tempered glass side panel, this accessory will fit perfectly into your case, allowing you to see your GPU’s power consumption in real time. Another positive point is that it acts as a U-bend, making it possible to conceal the power cable(s) more aesthetically. This is a considerable asset.
Our tests have demonstrated its effectiveness, and we can only encourage and congratulate Thermal Grizzly on the manufacture of such tools. Let’s hope to see more collaboration with Elmor in the future.
It’s hard to give it an award, as it can be so useful for a journalist that it’s of no interest to the average user. Let’s just say that this WireView works perfectly and is equipped with a whole range of parameters. It will also make the unsightly power cable “disappear”, while informing you of your graphics card’s power consumption. Priced at 49.90 euros by Caseking, this price doesn’t seem excessive to us, which is why we’ve decided to give it the innovationaward.
Many thanks to Thermal Grizzly for providing us with this test product.
