Conclusion
We have come to the end of this test of the Corsair RGB mouse pad. So what is this mouse pad worth? We tell you everything!
A good-sized mat
Corsair offers with its MM700 3XL RGB a good large RGB mouse pad. Indeed, in addition to offering a very large mouse pad lit by RGB, the brand adds an offset that allows you to add not one but two USB ports. Unfortunately, the RGB is a bit of a step back since the colors fade at the end of the mat. Otherwise Corsair has provided its mat with white seams that are only slightly (if at all) visible when the RGB is on.
As with the first MM700 RGB, we had no complaints about the glide of the mice either, since the fabric is smoother than that of the MM350 Pro Extended XL from Corsair.
And the price in all this? :
Corsair offers its MM700 3XL RGB for €129.99, which is almost double the price of the MM700 RGB, which costs €69.90. The bill is starting to rise seriously, especially since its performance is a little less “honorable”.
Corsair MM700 3XL RGB :
We liked:
- Its sobriety
- Its precise seams
- The presence of RGB
- To be able to manage the effects with the iCUE
- Its glide
- Its large size
- That it is flat on its ends
- That the seams are discrete (white) on the RGB
- The presence of the offset that adds two USB ports
We liked less:
- The RGB that runs out of steam at the end of the carpet
- Its price hurts
With this MM700 3XL RGB from Corsair, the quality drops a bit compared to the smaller version of the mat. We find a RGB that runs out of steam at the end of the mat. Nevertheless, we still find an offset offering two additional USB ports, sobriety, precise seams and especially a very large size. On the other hand, the bill increases seriously, this time to $109.99 or 129.99 €. For us, it will be the silver award.
Thanks to Corsair!
