Home Reviews GPU & MOBO Review: AORUS Z790 Tachyon
Overclocking.com video
The actual frequencies:
As with every new processor test, our first idea is to check if the announced frequencies are actually reached. To do this, we will use the Cinebench R23 benchmark. Two cases will be used: a single core bench and a second one in multi core. The idea is to be able to judge the frequency reached and thus, to compare with what was announced by Intel in its slides.
Remember that the Boost frequency in bench is different depending on the processor. Be careful, as Intel points out, when we talk about Max Turbo frequency, it is the maximum frequency that can be reached by one of the processor’s cores executing a single-core workload(mono-thread). This frequency varies according to several factors: the load, the cooling system and therefore the temperature of your processor. This is a notion to keep in mind. Here are the frequencies we should reach on a single core during our run under Cinebench R23.
First step, we leave everything in AUTO in the BIOS except the XMP profile that we load in order to have a frequency of 6000 MT/s in 30-38-38-96 for our memory kit. We don’t make any other changes in the BIOS.
Test with the i9-13900K:
Here we go with the beefiest of the processors, the i9-13900K. As you can see, we opened several windows to check the frequency and the temperature. The options in our BIOS were left in AUTO by default and only the XMP profile of our memory kit was loaded.
In single core, we can see that cores #4 and #5 reach a frequency of 5800 MHz which corresponds to what is announced by Intel. We can notice that the temperature of the two cores that are alternating at 5.8 GHz have a temperature of 61 °C.
When the 24 cores of our i9-13900K are solicited, the frequency is fixed on the P-Core at 5.5 GHz and at 4.3 GHz on the E-Core. As for the temperature of the hottest P-Core, it is 77°C and on the E-Core 63°C. Let’s not forget that we are equipped with a custom cooling loop of 480 mm. So if you choose this processor, it will be at least a very powerful AIO of 280/360 mm.
