Pulsefire Mat RGB: a bright mouse pad from HyperX!
We now leave on the side of HyperX which announces the arrival of a new mouse pad with the Pulsefire Mat RGB. It is a large format model with a bright light.
Pulsefire Mat RGB: an RGB mat and large format!
HyperX PulseFire Mat RGBWith this new mat, HyperX offers us a large format reference with dimensions of 90 cm x 42 cm. As for the thickness, we are at 4 mm, which ensures a correct comfort… At least, a surface softer than the wood of your desk.
Otherwise, we have the right to an RGB lighting in the form of a border that will go all around the mat. Via the NGenuity software, it will be possible to control the two zones of the carpet. Finally, there is a small memory allowing the storage of three light profiles.
Of course, the power supply is via a USB cable sheathed 1.8 m. Otherwise, it is a soft carpet with a fabric covering and a non-slip rubber base.
Finally, we end with the price, which is about fifty dollars in the United States. In itself, the price is pretty sweet, especially when compared to other models of the same type: XXL and RGB. Unfortunately, the brand has not yet put online the technical data sheet of its product.
