Computex is also an opportunity for be quiet! to unveil new products, including new cases. The program includes the announcement of the Light Base 900 and 600, aquarium-type models with a large RGB component.
Light Base: two cases, lots of RGB!
With this new series of housings, the brand offers two references: a 900 model and a second, smaller 600 model. The main difference between the two is, of course, their size, with support for E-ATX motherboards and two 420 mm heat sinks for the larger of the two. The smaller model will have to make do with ATX motherboard support, while the watercooling part remains compatible with 360 mm.
Of course, the main feature of these cases is their panoramic view, thanks to two tempered glass panels, one on the front, the other on the side. Obviously, both models can be reverse-ATX-mounted, or laid flat.
As you can see, aRGB lighting takes center stage, with 1.5 m of LED strip for the 900. Add to this Light Wings LX fans for versions with standard fans, and you’ve got some very bright cases!
As for prices, be quiet! has announced $179.90 and $187.90 for the Light Base 900 in black or white, without fan. With four 140 mm blowers, prices rise to $229.90 and $239.90 respectively. The 600 version is priced at $149.90 and $159.90 in black and white. Adding the fans brings the price up to $184.90 and $194.90!
As for availability, the smaller version will arrive in September, while the larger one will be available in October!
