XT M3: a micro-ATX enclosure from Phanteks!
Phanteks unveils a new case: the XT M3. This new reference is compact and uses a micro-ATX format. Nevertheless, the aim is to save space on a desk, while still being able to integrate large configurations. What’s more, the case benefits from a compartmentalized design .
XT M3: a compartmentalized micro-ATX case from Phanteks!
Phanteks XT M3With this model, the brand leaves the usual path of all-tempered glass aquarium housings. Here, we find a mesh front panel for maximum breathability and a glass side window. In any case, this model boasts the following dimensions: 235 (W) x 460 (D) x 370 (H) mm. Weight-wise, we’re pretty light at 5.57 kg, internally, the chassis is compatible with micro-ATX and mini-ITX motherboards. However, with a length of 430 mm, there’s plenty of room for larger graphics cards, without a front-mounted fan. The CPU fan is 175 mm high. Finally, the power supply is installed behind the motherboard tray and is only 150 mm deep. Ventilation features a total of nine 120 mm slots: three at the top and bottom, two at the front and one at the rear. This will enable 360 mm AIO radiators to be installed at the top. On the storage side, we’re sticking to a classic solution with two slots. The first will be 2.5″ only, while the second will be 3.5″/2.5″. Prices are rather aggressive for this model, which retails for around $70 on Amazon.com. The version with fans (three aRGB mills) can be found in the UK for around £60.
Here’s the Phanteks product sheet!
