Thermaltake announces the arrival of a new PC case, the View 300 MX. It is a rather imposing model with two interchangeable front panels. You will have the choice between more style or a better airflow.
View 300 MX: a case with two front panels to choose from!
With this new model, Thermaltake offers us a reference with a design quite similar to a View 71 TG. This can be seen in the beveled corners in particular. Moreover, although quite imposing, it is still more compact. This reference displays 230 (W) x 506 (D) x 505 (H) mm. As for the weight, we are at 10.4 kg on the scale.
Of course, with these generous dimensions, we have room for a motherboard in E-ATX format (33.02 cm wide) at most. Otherwise, seven expansion slots are present with the possibility of mounting them all vertically. Moreover, for the graphics card, the clearance is 400 mm max, 280 mm with a water cooling tank. Finally, for the power supply, we have 200 mm of depth.
The storage part highlights a HDD cage with two 2.5″/3.5″ baskets and four other 2.5″ slots.
Basically, the ventilation seems complete with two large 200mm aRGB mills mounted on the front. At the back, we have a small 120mm positioned for extraction. Nevertheless, you can supplement them by adding three 120 mm next to the motherboard or at the top. Otherwise, two 140mm slots are available at the top. As you can see, for water cooling, you can install a maximum of 360 mm radiator. Three slots are available: top, front and right of the motherboard. Finally, the selling price is $159.99 regardless of the color: white or black.
This way to the Thermaltake datasheet !
