Vegas A-series: multiple Akasa fans on one frame!
Akasa announces new fans with its Vegas A-Series models. Three sizes are offered with the A12, A24 and A36. Their particularity? To embark several mills on a single frame… A bit like the Antec Prizm!
Vegas A-Series: up to three fans on one frame!
Akasa Vegas A-SeriesWith this new series of fans, the Akasa brand offers three different models. We find the A12, A24 and A36, each with one, two or three mills on a single frame. The objective is simple: to simplify life during the assembly of its configuration. Especially since only two cables are needed for power and RGB management.
As you can see, the brand opts for white and a transparent hoop with the A12. Otherwise, the frames each have four silentblocks as well as small edgings on the edges.
Otherwise, on the level of the technical sheet, the brand mentions a power supply via PWM. The speed range will be between 900 RPM and 2000 RPM with an air flow and a static pressure of :
  • A12: 52.3 CFM and 1.99 mmH2O
  • A24: 109.48 CFM and 2.48 mmH2O
  • A36: 126.59 CFM and 2.36 mmH2O
Regarding prices, it will be 19.50 € for the A12, 29.50 € for the A24 and 45.50 € for the A36. An original solution, but which has the disadvantage of having to change everything in case of malfunction of a fan…
